Upgrade advice
  • Thread starter Thread starter Windspeed36
  • Start date Start date
Place a panel of glass on your carpet, then your tower. Problem solved. That what I did.
Otherwise reverse mount your psu.
CM storm styker, c70, 600t or 810/820 all good. Go with what you like best. Watch the switch 810 review by TTL. You'll run out the door to grab one.
The switch 810 is an awesome case but I havea hard time justifying the extra $50 which could go toward an H100i. Perhaps thats one reason I'm so drawn to the C70. It's got all the features I want. Key freature is liquid cooling ready. I like the case I have but the window could stand to be bigger and I dont know how the H100i will go with it. It'll fit for sure, but it will be restrictive in ram height.
