Hello forum members!
I am planning on saving up for an upgrade in the near future and was wondering if you guys could give me advice on which part to upgrade on my pc. My current spec is as follows:
Amd fx8350 cpu
Gigabyte a970 ud3p revision 1 board
Coolermaster hyper 212 evo
16gb mushkin ddr3 memory
Asus GTX 750ti
Cruicial mx300 ssd for os
Various mechanical drives for other stuff (games and audio)
Corsair cxm750 power supply.
Basically I'm looking at either upgrading the cpu which would of course involve new motherboard, ram and cooler, or upgrade the graphics card which would be a cheaper upgrade in the short term. My main uses of the pc are audio editing and mixing and playing games. If I was upgrading the gpu I've been looking at either the rx480 or GTX 1060. If I was to upgrade the cpu I've been tempted by the ryzen 5. My monitor is 1080p 60hz and I'm happy out staying at that for a good while at least. Which would you think would be better to upgrade now and which do you think could be done down the line? I have noticed the 750ti is starting to struggle with new games, (wolfenstein new colossus is unplayable at 1080p, mostly fine at 720p). If I was to upgrade the cpu I would need 16gb of ram for audio programs as they use a lot. Thanks in advance!
Amd fx8350 cpu
Asus GTX 750ti
