TweakForce 14.12 Omega Modded Driver
Dicehunter
Resident Newb
Tweakforce have been going for quite some time and with nearly every Nvidia and AMD driver release they try and squeeze a little bit more out of the driver weather it is a tiny bit more performance or increasing the IQ overall, Always worth a look.
In this update they have tweaked the following, Be warned though it is only for Windows 7/8.1 64 bit systems and AMD cards ranging from the HD5000 series to the R9 series.
XG drivers are generally tweaked to improve image quality while performance may increase or decrease slightly depending on your system specs. A few XG tweaks include mods to the following -
  • Paletted Textures In Video Memory
  • Render Quality Flags
  • Target Flush Count
  • Texture Clamp Behavior
  • Texture LOD Bias
  • Use Cached PCI Mappings
  • Texture Memory Space
  • Downloaded Memory Space
  • Texture Precache
  • UMA Fast Frame Buffering
  • Main 3D rendering
  • Triple Buffering
  • Area Anisotropic Filtering
If you are a Windows 8/8.1 user please remember to disable driver signing by following the guide here -
Or if you want a more permenant method you can disable driver signing completely by typing into the start menu or start screen "CMD" right click on it and run as administrator and paste the following lines in and press enter -
bcdedit.exe -set loadoptions DISABLE_INTEGRITY_CHECKS
bcdedit.exe -set TESTSIGNING ON
Now reboot your machine and driver signing is now permanently disabled.
Before installing it is highly recommended to uninstall your current driver and then do a driver cleanup using the latest DDU which can be found Here
And finally download the driver here -
Windows 7 - Click Me
Windows 8.1 - Click Me
Source - TweakForce
