i have just build my first pc it all works grate but i cant get the screen to fit my tv, it to big i have tryd to adjusting the res of it but it dont work any help will be grate thanks.
Are you using an amd gpu? Open CCC and mydigital flat panels- scaling- then use overscan or underscan so the picture becomes correct on ur telly. Im not sure what you do when using nvidia, but someone else will help you then. Good luck
if you're using a Nvidia GPU go to Nvidia control panel under the display tab select change resolution and make sure it's on the right resolution for your display
