TT amour
barginbin
What is the diffrent between the Thermaltake Armor VA8003BWS and the Thermaltake VA8004SWA Armor Extreme?
Thanks for any help :D
Guessing from the BWS and SWA
BWS - Black window steel
SWA - Silver window aluminium
Aluminium way lighter than the steel so go for that.
Ok thanks mate that sound about right as they have the same spec. That why i was woundering why there was a price diffrence.
Thanks for clearing that up :D
personally, i go for steel, as it is cheaper, and for some odd reason, i like my case to be heavy :P.
I also like the feel of steel!
The extreme version is mostly dedicated for the AMD FX which have to CPUs on one mobo and the extreme has to vents that go exactly on those cores so that there would be very good air circulation and thus better cooling.
