Where to start......
I run my HD 4870 which to be fair to it is still a pretty decent card for the stuff I use it for.......
It was bought 2nd hand form ebay, and has run fine apart from twice.
#1
About 5-6months of use it started to get the atimkdag.sys driver error, but after a lot of searching, I found there is no real fix......eventually this seemed to fix itself and was running fine for the last 4 months....
#2
Last night while playing COD4 my screen just went black and got the No Video Signal message, shortly after the game sounds froze up.....(black screen crash)
Now, I removed the card, cleaned it up, and got rid of dust and put it all back together again and booted up....
I can do everything fine (web browse, watching films, youtube, emails, even posting this thread) but when I try to play COD4, MW3, BO2 or Tricky Truck its loads each of the menu screens, but when it actually goes to load the play screen (where you can start moving around) I get a variety of different crash screens.....
Sometimes its a black-white vertical lines screen, other times it can be plain white with flashing red squares all over the place and even straight to BSoD (atimkdag.sys)
All things I've done in the past dont seem to be working, but what is getting me is that if I dont load a games, everything is fine.
I've just used Driversweeper to remove all AMD, and uninstalled the Device manager 4800 series driver... and have installed the catalyst set 13.1 so I'm back to where I was in regards of drivers, just this time all fresh...
Am I missing something ?
Edit:
I'm soon to be looking at getting an upgrade to a 7950/760/670 kinda card, but for now I want to sort this out....
#1
#2
Edit:
