Liarma
Ok guys I need some help here. Basically I want to buy 3x Benq XL2410T 23.6" 120Hz 3D Monitors and running them in Eyefinity at 5760x1080 at 120Hz.
I'm currently running a Sapphire Radeon HD5870 1GB which I know isn't enough for that setup so I'm going to be upgrading my GPU. I was considering the GTX690 but seeing the price that is now out of the question. I'm really liking the Msi 7970 Lightning 3GB. It has enough VRAM for that resolution and it overclocks like a beast.
The only thing is I've heard from some people that AMD cards have problems running eyefinity at 120Hz and you need an assortment of different adaptors to get it to work and even then it's very buggy and doesn't always work.
I've heard that Nvidia cards can do 120Hz Surround out of the box with no adaptors required and works flawlessly. But would rather not as the GTX680 only has 2GB VRAM and is a lot more expensive than the 7970 price/performance wise. And the GTX690 is almost $1700AU.
So can anyone tell me if I were to buy a 7970 Lightning what would I need to do to get it to run Eyefinity 5760x1080 at 120Hz?
Thanks in advance!
Thanks in advance!
