Triple 27" Monitor Stand?
infernouk
Hey guys
what are the options for 27" monitor stands that will hold 3 screens? I cant find any let along any at a good price!
Thanks for any help!
I'm sure you can find a cheap stand in amazon.com but first do check those guys.
Their stands are robust and I think I remember there was a "long arm" kit, for some of their tripple stands, to accomodate larger monitors ;)
I spent ages looking for one for my 3x 24"s. I couldnt find any that were reasonalbly priced and had the functionality i was looking for, i.e hinged arms. I found a few people using these. Couldnt find a uk supplier.
http://www.amazon.com/gp/product/B006FZY2XK/
I didnt purchase because i wasnt sure if i could get the angle I want.
yea i hear they dont support anything over 24 well, i need something for 3 27's but there isnt anything i can find even if i didnt care about the cost!
What you need is the Ergotech HD Triple Stand XL.
I'd put a link up, but I think it would break the rules of this site regarding linking to other sites (just google: HD Triple Stand XL, it's top of the page ;) ).
Ergotech aren't cheap, but they are well made and built to last.
I don't know what your budget is, but the guys over at Cotytech do some great stands, including triple 27", even 6x 27" if your mad enough :P
are they not all mounts? i need a stand ideally
also they are american? so uk shipping would be massive
They are american, but there are companies, like amazon.co.uk that sell them :) they are quite expensive though, so your budget may have to stretch a long way. It is a stand, but mounts on the back of the desk, it has a clamp that goes underneath the back of the desk. Hope this helps :)
