top of the range amd true sli board
BOOM-HE4DSHOT
HI GUYS LOOKING TO BUY A NEW BOARD WHAT WILL SUPPORT MY GTX 570 SC,S AS IM NOT IMPRESSED WITH THE CH IV EXTREME HYDRO CRAP! IVE GOT A 970 B/E CHIP SO HAS TO BE AMD SUPPORTED THANKS PEEPZ (BEST OF THE BEST PLS)
The G1 Assassin? Ignore this I did not read BE after the 970 *must not speed read posts*
Also there is no need to SHOUT WE ARE ALL FRIENDS HERE
caps fail
my advice 2 you is try and work thru the hydra stuff it should get better as it goes and maybe try the x mode instead of the fake sli options. Barring that if you do go another route send me a pm.
This might help some copied from Asus's website.
CrossLinx 3 Technology
[CrossLinx 3 Technology] [Hydra Logix Engine] Experience True Graphics Freedom
Lucid Hydra CrossLinx 3 makes it possible to combine multi-GPU graphics cards from any generation and vendor on the same motherboard. This gives PC users greater flexibility, and enables vastly increased performance, free of compatibility limitations.
Basically it does not allow for what we call SLI. It just allows for cross generation and vendor capability. I hope this helps some.
cheers bro my issues are the 2 cards being next to each other=hot + pc shut down when in black ops hmm very strange.and im not convinced im getting the power of the too cards gaming as is fps barely noticable with unlocked fps on 115 - 130 with one card with 2 cards 150?my m8 has a 6850 and gets 185 on one gpu:/
ah I see well I guess I missed that part in ur starting thread I can understand the heat issues but without knowing more about ur mates rig cant tell why his is better on fps than urs. and 115-139 I think is a very respectable fps. Might be that game is more optimized for AMD gpu's dunno as I havent played that game
that one looks good Neil and it spaces the cards out nicely but just my opinion I would think going with an Nvidia chipset would lower the performance as those afaik are older tech. I may be wrong just a thought. lol guess not as they have sata6 and usb3
It has true dual X16 PCI-E slots that do not downgrade to dualX8 slots when there is more than one PCI-E card on the board. That's why it's one that I have saved for future purchase. I want it along with a Phenom-II 1090T Hex core CPU and a few GTX560Ti's to SLI together. I even earmarked RAM that's made exclusively for the Hex Core CPU's. (It's right here)
doubt that tall fin design would fit under a nh d-14 but I may try it as its priced right.
I have ripjaws atm now they do pretty decent cant wait for my 1090t to arrive so I can see if I can get better. Which I am sure I can I got booted to 4ghz with this 925 from 2.8ghz stock.
San Antonio, TX, United States 03/02/2011 6:28 A.M. Out For Delivery
03/02/2011 5:17 A.M. Arrival Scan
03/02/2011 4:54 A.M. Departure Scan
03/02/2011 4:37 A.M. Arrival Scan
Louisville, KY, United States 03/02/2011 3:08 A.M. Departure Scan
03/02/2011 12:01 A.M. Arrival Scan
Memphis, TN, United States 03/01/2011 10:01 P.M. Departure Scan
03/01/2011 8:34 P.M. Arrival Scan
03/01/2011 8:20 P.M. Departure Scan
03/01/2011 5:49 P.M. Origin Scan
United States 03/01/2011 12:03 A.M. Order Processed: Ready for UPS
sry headshot we kinda hijacked ur thread but were still here to help
