!TIMMY!'s Logitech G15 Custom LCD Studio Config
Yes go to: Options > Preferences > Global Hotkeys and tick the Enabled box, then close.
Then the media keys will work all the time.
wow dude you are amazing :D
once i instll this, to go back to the normal one, would i uninstall? or just switch it to the next one?
Ive saved over my original files so both configs are named the same.
You can set up the LCD screen to rotate through all ur enabled configs (custom and default) and set the time it will show each one. Or u can do it manually with the little round button next to the LCD. You just need to set it up in the Logitech LCD Manager that you should have installed with the Drivers.
Just for a bit of input: On my G15, I don't use LCDStudio and have the following screens:
Everest Ultimate Screen : Core 1 temp, core 2 temp, gfx temp, mobo temp, ram and cpu usage.
FRAPS Display
Ventrilo Display
Media display for Winamp/Media Player
but nice work Timmy :)
Outstanding work.
The G15 controls and stuff can go goofy, often from u plugging it into another usb and windows gets confused. U plug it back and u`r in screwsville. Reinstall of the logitech thing sorts it out.
Have u been to the G15 forum thingy (which I can`t remember site of atm) - has some really sad looking crap on it tbh. But there`s a devs kit download too, which is semi interesting.
And if u got AMD, the info tool is pretty much a waste of time. Tells u what cpu u have plugged in... with the default clock speeds etc. Ignores any oc.
Oh and my lcd thing is burnt, it`s worth cycling displays.
Hi
When I click the d/l on the page 1 of this thread it doesn't give me a file just a 1k unrecognised file. Am I doing somthing wrong?
Kind Regards
Gav
I am experiencing the exact same issue with both download links in the original post. They download as
!TIMMY!'s_Logitech_G15_Custom_LCD_Studio_Config.ra and
!TIMMY!'s_Logitech_G15_Custom_LCD_Studio_Config_27
respectively, and they are both 0 bytes!
name='blueguava' said:
Hi
Kind Regards
Gav
i have the same problem mate,
i really wanted this as i cant seem to make a good config with lcd studio
