SieB
Have you looked at the Silverstone TJ07 S_I_N?
It's a bit on the expensive side but you might be able to get a secondhand one cheap. You can fit a thick 360 or even a 480 in the bottom you just need to get a radiator stand you can also fit a slim 240 in the top as well.
Not many cases take a thick 360 up top without having clearance issues, the best cheapish all rounder is the HAF, the Xigmatek Elysium is also a good choice but it is huge.
See this for pics of the TJ07
http://forums.bit-te...d.php?p=2348182
