thickys 6800 1m
bazx
been working on petes 6800 on windows 2003 with a Little Devil copper base pot
and some Ln2
i had a 9.31 but over filled the unit and it froze
That is very nicely done mate and definately the uk's fastest,congratulations.I haven't had chance to install the quad yet,not sure i will either at this rate.
sorry to here that pete i can send this one back to ya this week
unless you want to swap:D
the cpu is running at 5511mhz @ pot temp of -150c /1.8v
m/b is commando 0902 bios
g.skill hz 512 x 2 1:1 fsb 459
os is 2003 server
congratulations baz on some excellent results, very good job mate and well done again must be the fastest in the UK for sure.
thanks paul i will try again and drop a multi to 11x i am sure this is where
the big score is hiding:D
nice going there bazx:D
have order myself the same mobo, get that E6600 running where it should be.
could you send me or thickie the v\mods for the commando please bazx, or post a link for them, cant seem to find any anywhere:(
thanks kenny been trying 11x but just cant get the oc over 5350mhz
this maybe the limit of my ram or fsb
pants persivore did the mod i will see if he has any pics
name='bazx' said:
yes but you need to make a few changes
it has to look like the screen you see above
Found XP to be slightly qucker for 1m runs, with 32m faring bettering 2k3 server. Unless I'm missing a tweak or 10 (which is pretty likely :p)
Oooooh gettin closer!! tRRD can probably come down a fair bit (<5 easily) and tRFC can maybe get down to 19? Write to Precharge can definately come down another notch too :)
Hope that helps slightly
it does kenny thanks
i was not really set up for pi benching but my gtx has died so have been working my way thro the rest of the ln2 with this
i am very new to pi benching so there is no dought others would have done better with these clocks
