Mickypheonix
Hi guys ,
Firstly this is not a case review just my thoughts on my new purchase.
I have never owned a thermaltake case and am certainly not a fan of theirs.
I know there are a lot of thermaltake case haters on this forum and with good reason, I believe Thermaltacky was a quote i saw recently
I just bought a Thermaltake Core V71 Full-Tower Chassis and was worried after talking to members about weather the build quality of the case was crappy.
It arrived yesterday and i was pleasantly suprised
I Have 2 Hafx cases and really like the build quality and have mates with corsair cases and quality of those cases is excellent too.
Being in the metal trades for a living i can tell poor build quality when i see it,
Believe it or not the build quality of the case is excellent and is mostly all steel. It has a fully modular desighn and heaps of radiator support and a large window.
The first thing i did when i got this case was to pull it out of the box and give it a thorough going over.
Both side panels are strong and not flimsy at all ,the side window is solid and not cheap and even it can be removed and replaced.
The way the side panels mount onto the case similar to the hafx and works well.
The front of the case and top are mostly steel mesh with some plastic but they also are solid and not flimsy ,the rest of the case is all solid steel and not cheap bandy rubbish. There are also removable dust filters all over the case which is good to see.
I pulled out the hard drive cages and checked them , they are all solid steel and the quality of the hard drive holders is good solid plastic like the Hafx , the way they mount in the hard drive cages and the locking mechanisms are really solid and not flimsy at all.
The modular system works well and is easy to remove and swap hard drive cages even when they are mounted in various positions without the front rail to hold them the way they attached to the case frame with thumb screws is rock solid and they don't move.
Please ! Tom ( Guv ) do yourself and your viewers a favor and check out this case ! the price is awesome too , IMHO i reckon you would give it a gold award if you checked it out
For those who have not seen it here is a link
http://www.thermaltake.com/products-model.aspx?id=C_00002231
I just thought i would share my thoughts on this , because there are a lot of cases on the market now and i really do believe thermaltake have finally stepped up to the plate
