name='Austin' said:..You didn't actually use the CPU with the thermal compound still there did you?
name='harrej' said:i put new thermalpaste and some went between the pins is that dangerous??
name='muffin said:erm...the obvious question is how[/B']? The pins are in the socket...and unless your really cack-handed I fail to see how it got on the pins if you put the TIM on while the CPU was out of the board...
name='harrej' said:ni i have socket 754 amd athlon 64 3500+
name='harrej' said:no it was upside down and then i dropeed some!!![]()
