Hi all,
Decided to put up a few shots (albeit bad ones) of the current build I am working on. Not far from finished by a few things I need to complete or not too happy about.
The design is based on the Warhammer 40k Army "The Necrons". The reasoning behind this is that a good friend of mine was a Necron fanatic. Sadly he passed away this year, and so I thought it would be a great way to pay tribute to his passion by using his army as inspiration.
Just a couple of pics of the miniatures so you get the feel or the idea of it.
So here it is.
Specs
Hardware:
CPU: Intel 3570k @ 4.6 ghz
Memory: G-skill Ripjaw 8gb
GPU: GTX 780 x2 @ 1200
Mobo: Sabertooth Z77
PSU: Seasonic 850W Ultra Quiet
Soundcard: Xonar Essence STX (missing from case at the moment)
HDD: 2 x Samsung 840pro 120gb in Raid0
1x Samsung Ancient model of forgetfullness 500gb HDD @ 7200rpm
Fan controller: Lamptron CW611
Waterware:
CPU: EK supremacy
Rad 1: EK XTX 360 Rad with EK fans
Rad 2: EK XTX 240 Rad with Corsair SP fans
Pump: Swiftech MCP 35x
Tubing: EK HD Tubing 16/19mm + additional from local store (Plastekompaniet)
Fittings: Various EK PSC fittings 90,45 degree and EK HD Male/Female acrylic tube connectors.
GPU: 2x EK GTX Titan full waterblocks
Reservoir: EK X3 25cm Multi option
One thing I am currently impressed with is my choice of TIM. Decided on the Cool Laboratory Liquid pro. This stuff is phenomenal. Noticed my GPUs have dropped an additional 6Celsius and CPU dropped by 8C after switching from the MX4 paste. (IHS is lapped and crappy paste replaced with Liquid pro in between the die and IHS) As well as between cpu and waterblock.
Anyways, sorry for the bad pictures. I didn't have the lense I wanted to use as its been borrowed by someone.
The annoying white cables of the UV lights above, will be hidden soon once I drill a hole in the centre of the mid panel I made.
The OCD in me needs to readjust the higher tube so its parallel with the other.
I just find this UV green Mesmerising
Double barrel whammy!
Here is one most people usually are afraid to show. The cable management. As you can see, mine isn't that great but will be sorted once I get my PSU cabling sleeved.
Things on my to do list still.
PSU cable sleeving: Plan to get these done soon. Hopefully PEXON can fulfill my wishes
Re-colour the heatsinks on the Memory. I'm undecided on what colour. I'm thinking either black so they are not visible in the dark, or UV green so they stand out. I'm not one for going with 4 sticks. 2 is enough so maybe the UV green won't be OTT.
Recut the entire Acryllic back panel so it is one piece. If you notice the separate cuts this is because of a disaster crack in the sheet that occured. Sadly I had the last sheet from the supplier so had to make do with what I could.
I also plan to cover the rear panel as well.
SLI bridge connector. Currently working on an acryllic connector to cover those nasty looking asus bridges.
Something like this.
That about sums it up.
All I can say is.
Merry Christmas!
So here it is.
Specs
Hardware:
Waterware:
CPU: EK supremacy
All I can say is.
Merry Christmas!
