Hey guys I'm a first timer on the forums and also new to windows. I've always used Apple products until I tried gaming on an apple in "BOOT CAMP" HAHA I've had the rig about a month and have already made a few upgrades since.
Specs:
CPU: Intel i7-4770k Overclock able edition "to scared to do it."
GPU: ASUS DirectCU II OC 770 geforce GTX
RAM: "upgraded" 32GB Corsair Vengance
Mother Board: Z87 Sabertooth
CPU Cooling: H80i push pull
Power Supply: Corsair HX1050 Modular
Wireless card: ASUS dual-band wireless-N600
SSD: Two Kingston Hyperx in raid 0 I think.
Case: CM STORM Stryker XL-ATX
Ineed a bigger desk but for now it works.
My cable management needs work but its my first.
I have a total of 6 fans on the HDD's
I got the case for 90.00$ USD full atx-x or something along those lines
I did some custom drilling to mount fans in the front there are two 120mm in the expansion slot things. As you can also see Two upright SSD along with the HDD below.
As you can see they stay hid behind the expansion slot fairly well with some zip ties. Im going to be getting better fans soon.
Fairly tidy.
as you can tell by the power supply I did not know what i was doing when purchasing all of the components. I had a lot of help from some Teamspeak friends.
Don't Get me wrong i still use my mac's "Shots fired"
My work area and a better lit side view of the case.
I used paracord to sleeve with. I am still waiting on my neon green to come in on Friday so i can finish the 24 pin and so on.
I liked the seamless look better that having the heat shrink look. Thanks http://lutro0-customs.com/ for the idea.
Here are the temp diode things with sleeve. That im going to run to the power supply, Hard drives and in the Corsair radiator.
Specs:
Fairly tidy.
