Many have come to the dungeon of offtopicness. That's what they all say shortly before realising there is no way out and they are trapped in the thread forever![]()
DUN DUN DUUUUUUUUUUN! I love Iron Maiden...
Haha SCAN FTW! Do you think a Corsair A50 will be substantional enough for 4Ghz on a AMD Phenom 955?
You can but not stable. Even I can only get 3.8Ghz stable on my 1090 but I haven't tryed 3.9Ghz yet, only 4.0Ghz which buckled under prime. An A50 will probably run into heat issues under max load too. I'd go for a minimum of an A70 or if you can house that just join the D-14 club
I knew I should have baught a CM 690 instead of this Vulcan. A 955 is a quad core...![]()
I know but it's still pretty similar to the Thubans (though not exactly, obviously)
I once accidentally melted my Vulcans front panel with an overclocked lamp...
the_bowus?
SPS Industries. I like sound of industries
wont be using a custom domain name, just want something I can put on CVs![]()
