alienware
Banned
Right. Got a few hours on my hands whilst peering out of the window hoping on a parcel, so let's get the latest one ripped to bits and exposed for what it really is, shall we?
A few months ago I decided to clear out some of my PCs. It was getting daft, especially considering that they were all crammed into a 2.5x3m room. The first to go were my older Alienwares, both the ALX and the black 2.0. This cleared up space, but more importantly funds to have some fun with.
It had only been about three months since I built my I7 950 based around a Bitfenix Survivor and so I swore up and down I wasn't going to buy any more computer parts for at least a year. Like an idiot I had a quick glance on Ebay, only to find a company selling X58 based brand new Alienware part builds for £325 shipped. Ugh.. Must.say.no.. Too late. Buy it now it was, and a few days later it came. I had managed to restrain myself for a few hours, having a look into what I was getting. I didn't overclock my I7 because in all honesty there was no point. The 950 is a ferrocious chip and doesn't need any assistance over its turbo function to bash any known game on the market today into submission. So, with this in mind (and my Bloodrage to back me up) I ordered it.
I did, however, see this before ordering. It seems that X58 Alienware parts were becoming abundant on Ebay given that Sandybridge was now launched and fixed.
It's an X58 micro !. But, it holds a secret. See if you can find that secret, and if you can't then later on I shall point it out. I knew what I was getting, and I knew it was a board in the same calliber and league as a Rampage Gene or whatever they are called. Not a cheap board by any means.
A few days later it came and I had a chance to look over it. Let's see if they're a bit pony like people assume, or, whether they actually carry quality parts.
So here it was. Brand new in all of its splendor.
And as promised it was exactly as described. Brand spanking new, flawless, still covered in plastic wrap inside. The case itself is usual Alienware fare. Triple walled side panels, weight around a metric ton and decked out with all sorts of loveliness that people can't "see". At first glance it just looks like a semi matt to eggshell finish, but, look a little closer and it reveals a secret.
It's not paint at all, but rather 'moondust' or whatever the hip name for it is, powdercoat. Outside the quality was beginning to match up to prior Alienwares, with Dell pushing the boat out. I will also point out that on the back of the unit near to the IO shield is a touch button. Press it and the entire back of the PC lights up with white LEDs so you can see what you are doing when plugging stuff in. It's squat, it's compact, and with my new solemn swear never to play with SLI or Crossfire again it was ideal. This was ruled out by my enormous triple slot Zalman GPU cooler any way, and a good thing. Moving on then the MSI thing was revealed once and for all.
It seems that MSI are making the boards for Dell to put into these Alienwares. Is that a good thing? Well, after the review prowess of MSI over the past two years I would say so yes. This isn't a new thing, MSI make all of the boards that go into the Acer Aspire Predators too and have done for years. Taking a closer look at the motherboard revealed an absolutely monstrous north bridge cooler with a large fan atop. So large infact that I had to remove it to have any hope of getting an NH-D14 on there, and still so large was this NB cooler than I had to chop three fins from the bottom of the Noctua in part so it could wrap over the NB cooler. Gone was the silly Asetek LCLC as I have had one in Corsair guise.
So, now it was time to find out where all of the fans are hidden. There is one hiding in a front duct and one hiding in a bottom duct. The front duct caters to the GPU/S whilst the lower duct takes care of the hard drives. They are both 92mm affairs, but when popping them out I discovered something else rather revealing.
Those are Deltas. They offer up huge RPM and CFM speeds and cost a fortune. About £25 each if memory serves me well. This did have me worried somewhat as they sound like jumbo jets taking off, but my fears were to be eased later. In the back of the unit is an obligatory 120mm unit that did not arrive with the PC (nor was it supposed to, it connects to the H50 thing) and again, is a Delta. I decided on Noctua, as always.
So, in went the said Noctua. This is the only way it would fit. If I turned it into normal business position it hit the top of the case.. It draws air downward, through the cooler and out of the back. It works well, offering the same exact temps as it did the other way in my Bitfenix. Now, going back to the top of the case you will have spotted a small circuit board that the fans connect to.
Remember this, it will come into play later. A little while later the hardware was wired and fitted and looks like so. Not the tidiest PC I have ever seen and the cable management isn't fantastic, but it gets the job done and doesn't have a window. So unless you have case OCD and take your computer apart all the time it doesn't matter.
Time to close up the duct then.
And have a play. Once started something rather odd happened.
The bios listed did not exist. Hmm, odd. It turns out after contacting Dell via their support website that the bios that was on there is a engineer's bios used to program the onboard toys. This includes that board you saw earlier (which turned out to be an electronic PIC controlled fan controller complete with temp sensors and auto fan adjust software like Afterburner) and the lighting board that is also PIC controlled. This is how they set the default requested light colours and so on. I decided to update it to the newer bios as I had heard a rumour going around.
The rumour consisted of one rather irate American who didn't want to pay for Alienware to put a pathetic overclock on his new system and charge $250 for it. He threatened Dell with legal action and a couple of months later the newer bios revisions looked like so.
XMS control, frequencys, voltages it's all there. This is now a boggy standard MSI we are playing with and one that was indeed capable of getting my 950 to 4ghz (as I already tried and confirmed it). So there's nothing sinister or monopolised here.
Once into Windows I had a go on their software. Here is the thermal application. It offers full control over every fan in the system via the electronic board. This includes seperate fan adjustments, automatic fan adjustments per degrees C and as many profiles as you like. In the end I decided on 25% for normal use, with a 50% option for gaming. Trust me, you don't want to put them to 100% as it literally sounds like the PC is going to blow up.
And the next thing to play with was the lighting software. Again I got a couple of nice surprises here. Firstly you can change them to any colour you like. Whilst childish this is a lot of fun. Then you can have them morph, flash, pulse and all sorts of utter sillyness. However, where it becomes clever is how you can program said lights to react to certain things. If you get an email whilst gaming the lights can be programmed to flash a different colour. And so on and so forth. And whilst these lights are quite frivolous they are there, and I would bet they cost a pretty penny.
In action.
http://www.youtube.com/watch?v=66kh9jUgOP4
And when I got an email.
http://www.youtube.com/watch?v=s6x4Oqs7-i0
So that pretty much brings us to a conclusion. The first thing we need to do is price up the chassis itself. I can put a $350+ price tag on it from the off. Firstly let's consider than it contains $75 worth of fans. Then let's consider it contains two programmable PIC boards that needed to be designed and then have software written for them. Then the finish, the good quality parts, the power supply. There is nothing cheap in there, and everything is incredibly solid and heavy. There are even flashes of genius about it, like the LEDs on the back to light the way.
Are they worth the money? it depends. Firstly I will say that there is utterly no point to buying an entry level Alienware. The first problem is no matter what route should you choose you are always going to come back to that 875w 80+ silver PSU and the horrifically expensive motherboard habit that Alienware have always had. It's over engineered to the point of ridicule and excessive to the point of laughter. But, it is what it is. A tremendously high quality unit decked out in sheer luxury. Getting a high end one is a good idea, which, brings us to the ALX.
Is it worth getting an ALX (I noticed this was mentioned elsewhere). No, absolutely not. The ALX carries an extra £3-400 price tag for what is nothing more than a lovely keyboard and mouse (TACTX by Logitech) and some vents with a few extra lighting zones. However, taken into account that the case already has the frivolous lighting AND that the vents do absolutely nothing but look quite fun then that pretty much rules out the ALX. If you have the money and it's no object? then sure, go for your life.
It's also not a good idea to start upping the spec when on Dell's site. They do overcharge for 'upgrades' so it's far better to buy one with a good GPU and CPU combo and then add in any optical or hard drives yourself.
So in all honesty nothing has really changed since the takeover. You get a very high end board coupled with a love it or hate it solid heavy case and some pretty good software and ideas. You get a sterling warranty service sans risk and literally take it out of the box and game on it. No hassle, no headaches. Dell still maintain the expensive component habit that Alienware did, so once again speccing like for like would cost you like for like, especially when you price in Windows 7 (a genuine one) and an onsite warranty and the guarantee that your system should work.
So the only surprise really is that the groundhog day shall continue. The haters will continue to hate, and those with very wide open eyes will see them for what they are. I couldn't care what PC my Left 4 Dead chums use at the other end of the internet, as long as it works.
In action.
