The 'Best' R9 290?
Bang
As per the conversation in another thread, I was told to start a new thread.
So, what do the fine members of OC3D consider to be the 'best' R9 290 and why?
Personally, I have to include warrantee as part of the 'best' on a video card. I once had an XFX card which lasted all of two months past its 1 year warrantee. Needless to say I've thought XFX was junk ever since. Times have changed, and so do reputations. The only card I ever had to RMA was an Asus 4200, which they upgraded to a 4600 and I was a happy camper upon the cards return.
Other companies, like XFX had, and may still have (I dont know) lousy customer service, as per the other conversation.
So, what makes your 'best' R9 290 and why? It's not only about clock speeds and benchmarking. I would also include warrantee and customer service as part of the deal. If you are paying $500 or more for a GPU, you obviously want the manufacturer to stand behind their product.
My opinion as per Toms reviews among others, was the MSI R9 290 Gaming was the best you could get performance-wise and it also comes from a very reputable manufacturer.
Am I just being an idiot for not shelling out an extra $100 and going for a 780? Or save money and go with a 770, though it seems a step down from the 290?
With the noise my H100i makes on performance mode, noise on a gpu isnt really an issue. Power consumption and heat arent really issues for me.
So, please consider:
Price, performance, warrantee, power draw, heat and noise when you answer as these are the major issues with gpu's these day when you answer.
Feel free to expand on your answers explaining why some are better than others, and thank you.
power draw and noise isn't the 290s strong point imo. That said, even though the warranty isn't that great I'd get a Sapphire Vapor-x 290 if you're not planning to watercool. Thing runs cooler than most 780s and overclocks very well. If you are then Powercolor are the way forward as I believe their warranty covers issues with a card with a water-block on it.
Also any company that makes an Aircooled 290x2 (not 295x2) is so darn mad they deserve my vote any day.
In all honesty, I probably wont be overclockingthe card much, if at all. Who knows though? I might get a wild hair and run some benchmarks and do some hard core gaming :D It'll be more of a mood thing than 'gotta overclock it to max 24/7.'
I definitely wont be water cooling as I've got a case of CBF. All I want is a good card which will last me for years, far beyond the warrantee period. My little GTX550Ti has lasted the 3 years of its warrantee period, but its time for a major upgrade (not that it was a great card when I bought it.)
All the advice, the why's and the why nots are truly appreciated. When I drop $500 or maybe more on a card I want to make sure I'm getting a bloody good card, otherwise I'd just drop $199 on a 660 and be done with it, without the worries because its only $199, not $500.
My main goal in getting any R9 290 is: tripling my current gpu's performance and getting new technolgies like Mantle, which looks like a serious performance booster, compared to even 280X's.
The four best 290s are.. in no particular order
Sapphire Tri-X
Sapphire Vapour X
Powercolor PCS+
XFX DD
The other 290s are good cards but they aren't as good as the ones above.
The MSI Lightning is probably THE best, but it is expensive compared to the others and unless you are doing some heavy overclocking it isn't really worth the extra.
The Asus 290s are probably the least good 290s due to the coolers on them being the worst.
If you go for any of the 4 I mentioned you will be happy, they are pretty much as good as each other when it comes to cooling, temps and noise.
I have a Tri-X 290 myself and it is dead quiet, max temps while gaming are about 72*c and I can't hear it making any noise over the other fans in my case, so I definitely recommend it as a good card.
I really like my Sapphire Tri-X R9 290, have it for 1 month now. For some reason all my past gpu's were Sapphire ones (HD 4850, HD 7870). I was considering the GTX 780 or the R9 290 (almost the same performance) for a long time, but the almost 100 euro's (premium) price difference for the Nvidia one wasn't worth it at the end for me. GTX 770 is indeed a step down, but decent enough if you're playing at 1080p. 'Noise/performance ratio' is perfect IMO. My 550 watt bronze psu runs it without problems. Only had a few bsod, has something to do with hardware acceleration. Disabled it and since then no bsod anymore. The other con is, it won't fit most of the popular m-itx cases due to the size of cooler.
