yassarikhan786
I don't like C-net reviews either. Very crap reviews imo.
Im still in love with 1680x1050 myself ^^
I bet you a 24" 2560x1600 display will look EXACTLY the same as a 4k 24".
I disagree, some people wont notice the difference while others will. This is like saying 60Hz and 120Hz look exactly the same and you can't tell them apart - quite a few can, varies case by case.
I think this will end up being something that no one will notice a difference. The pixels will be so small on a 24" 2560x1600 that there will be no difference from a 4k display. There is a little bit of difference from smooth motion and the size of a pixel. once pixels get to the point of not being visible to the human eye, it would be completely unnecessary to move to a higher res. My example was if a 2560x1600 display had pixels so small that you needed a magnifying glass to see them (20/20 vision of course) and a 4k display was the same, you would not be able to see the difference unless you were playing 3" from your screen with a magnifying glass.
I really want to see 2560x1440/1600 displays but unfortunately the only company that wants to push them out is Apple. Massive speculation here but I think Apple will release a TV (which everyone will go buy so they look cool) with qHD resolution, other manafacturers would follow the lead and quickly surpass it with better displays. Voila we have our qHD displays. I told you it was massive speculation xD
I hope we see a shift within the next few years so we can stop being so dependent on anti-aliasing.
I hear this claims of not being able to see the pixels quite often with mobile screens which have very high pixel densities. A 24" 2560x1600 monitor doesn't come close to the densities that are common on mobile screens - I can see the pixels (if I look for 'em) on a 'retina display'. I'm pretty sure I can see them on a qHD monitor too.
Another thing we can benefit from is with 4k resolutions we wont even need anti aliasing to the extent we do now.
I agree there will come a time when we wont need to go any further but qHD isn't that time.
