Temps seem high?!?!
humblingly
Rig:
i3 2120 (stock)
hd 6870 xfx double fan cooler (stock)
MSI Z77A-G45
4gb corsair vengeance (in 2nd slot due to overly sized cpu cooler)
500 gb western digital hdd
600 watt corsair cx600v2
coolermaster elite 430
Hey guys i just installed my nzxt 140mm cpu cooler and 4 bit fenix spectre pro fans in my rig about a month or two ago and i was wondering what you guys think of the temps because to me they seem pretty high. =/
idle
cpu:30-33
gpu:37-40
but after about 3-6 hours of gaming on high details the temps go up to
cpu: 45-50
gpu: 55-62
the only thing that i think could be making the temps go up so high is my brothers computer he doesn't have any additional cooling apart from the stock cpu and gpu coolers which i think is feeding hot air into the room also the case that i have is pretty packed full and i don't think that there is much room for air flow with in it. =/
Any thoughts would be great!
agreed nothing to look at here surprised you say there's not good air flow cause those temps are good
i concour, your temps are where they should be. maybe you might look into some better
case breathing, but for 2°-5° difference.. if anything i'd prolly help the GPU from bar-b-quing
the CPU air supply.
airdeano
