Tall order, small factor
KING_OF_SAND
I am looking for a micro ATX case (or a really small one) that meets these two specific requirements. It must be able to support a 240mm RAD (H100) and have a fan that can blow IN air at my GPU(s) (GTX570). My price is $150, if one that cost more is found, please post it anyways.
Let the hunt begin.
I was looking at that one. It is a nice case but airflow is pretty restrictive in that case, and I am not to fond of the quality. I actually just picked up a case today at Frys. I was deciding between the Cooler Master 690 II and the R400 from Corsair. And decided on the R400 because of its better cable management and the whole Corsair theme. Got Corsair RAM, PSU, H100, SSD, and USB drives. Also the 690II seemed a felt a bit cheap when I was fondling it.
Its always good to give it a good fondle before you buy it - if they let you that is.
wow, from small and demure to plus size. the arc mini is a fine air case. tom's review of its larger
brother arc midi toughted a great air case from the fan placement and the options of WC. the
mini using 120 fans in place of the 140 in a scaled down version would have made an ideal micro.
just my .02
airdeano
