P Pugsport Member Jan 21, 2018 #1 Just after some advice as to which wiring format to use on my new home network, just pulled my house apart and added 500 meters of CAT 6a cable but im now unsure as to which format to use
M MadShadow New member Jan 21, 2018 #2 Id say just use T568A since that's what is most widely used nowadays. Give this a read: https://acuitysupport.zendesk.com/h...8-What-is-the-difference-between-T568A-T568B-
P Pugsport Member Jan 30, 2018 #3 MadShadow said: Id say just use T568A since that's what is most widely used nowadays. Give this a read: https://acuitysupport.zendesk.com/h...8-What-is-the-difference-between-T568A-T568B- Click to expand... Thanks for the advice Madshadow and sorry for the delay in replying been a little busy
Robi_G New member Feb 7, 2018 #4 They'll operate exactly the same, two of the colours are just swapped over. Just be consistent with whichever you get.
