Swiftech H220X
kenny01924
1453339_555580477867171_1305846938_n.jpg I like the look of this the new swiftech h220x have a look this is out on sale from the 1st of may I think I can see one on order soon the pump is faserned to the radiator in stead of the block and the block like the cosair h100i as wait for it light on it which you can change colours mmmmm
Not sure about this one. Just the format of it with the unit just being sat on a cushion in someone's house seems very familiar ;).
On a plus note, I really like that block. Has it been released before or is it new with the AIO?
Fire isn't going to be enough for this one, we need to pour acid over it and let it dissolve.
The concept is good but it just looks so wrong, they should of kept the pump on the block. It's only a skinny 240 rad, it's not like having a more powerful external pump is needed. It is just going to be noiesy, I like how you can change the fittings and essentially change the tubing as well though.
Performance will probably be very good, but I bet it will also be expensive especially seen as he Apogee block costs ~£60 on its own. Also compared to other cheaper AIOs it will probably wont be worth the extra money, unless you do really want the customization options. But then again you might as well get a proper custom loop if that is what you want.
I like the look of the waterblocks but those radiators I don't like.
Did anyone else pick up on the Haswell 6 core comment?
But you can color noctua fans, there is nothing you can do about the looks of the swiftech, it just looks plain stupid.
To you it looks stupid but you have to remember there are a lot of people on this planet and they all like something different :)
Personally I think it looks kinda cool, If it peforms better than Corsair's offering I might get it and have a play around ^_^
Noctua products look like crap but perform great, Not always about the looks when it comes to components.
h2F5FE76F
I agree, it doesn't look that bad. But if it's no better than the other coolers, I see little point in buying it. Especially since it will probably be more expensive, just like the H220 was.
The CPU block is pretty cool.
