So, my first GPU had temp problems, 15-20c higher than the second. This was mainly because my second GPU, blocked it's airflow pretty badly.
I decided to swap the cards places for the hell of it. Seeing as the second GPU seemed cooler in general. That solved my temp issues, oddly enough, the first GPU, now with enough air flow, seems to being alot better. No dust or anything either, I should change the thermal paste, but anyways, for now, it works.
Weird issue is...Desktop is fine, videos are fine, ect, nothing appears to wrong.
Except: in-game SLI, my second GPU, previously my first GPU, is now used about 20% LESS than my first GPU, where in the past, both GPU's were used equally. I tried disabling and re-enabling SLI to no avail.
Also, I get a strange color flashing thing, that looks like it's switching constantly between 16bit & 32bit. It's quite odd. Disabling SLi seems to fix this issue...which means, well, I don't know it means, something wrong with the second GPU, that was previously my first GPU?
