Suggestions on rig lighting
SillyOldSquid
Hi all,
Okay so i want to buy some LED lighting for my rig.
What do you guys suggest?, I want it to be in LED strip/cable form and i want it to be blue.
I was thinking along the lines of Bitfenix alchemy LED strips but they seem quite expensive.
The Bitfenix ones are very good, even a small strip of them will light up your entire case. Make sure you get the connects though, don't really see the point in the aquas.
Depending on what you're wanting to light up and the case you're using, you may be better with white LEDs however.
Thanx, yeah I was planning on going for the Bitfenix LED strips, I'l probably get like two or three 15cm strips and im sure that will light up my rig nicely, also do you know where i could buy them at a reasonable price?
Would you run them in connect or separately?
45cm of it will be very bright IMO.
You should either go for a small amount of the Bitfenix ones (20cm ish) or get something like the NZXT kit where the LEDs are spaced a lot more and so won't be overpowering.
I was going to run them separately in places i wanted to highlight.
i think i got mine from amazon, specialtech also have them, they weren't that different in price, 3 x 15cm may be too bright, 1 is good enough to light ur rig so maybe play safe and get 2 but i suppose it depends on ur case and hardware
NZXT Hue
Any colour, static or blinking. £25
I like that i would have more options with this product but have you ever used it?
If you have what is the face plate like it looks kinda cheap and flimsy...
Also is the led strip flexible enough to get into the corners of my case without it bulging out ?
