BigIan88
So im looking to buy a new monitor next week as an upgrade from my LG E2240S 22" LED Monitor.
The monitor I have is a fantastic all rounder and ive never had any problems with it, however I would like something a little larger and preferably with a higher res if possible but must be LED (backlit).
Ive been browsing the Aria pages and came across these 3 monitors which caught my eye but id like other peoples opinions on which to buy.
1) 23" LG IPS231P-BN
1920x1080 Resolution, 5,000,000:1 Dynamic Contrast Ratio, 250cd/m² Brightness, 5ms Response Time, 1x DVI-D Input, 1x VGA Input, 3 Years Warranty - £159.95
Better panel and colours thanks to IPS but not much in terms of a size upgrade.
2) 24" Iiyama Prolite E2473HDS Widescreen LED Monitor
1920x1080 Resolution, 5000000:1 Contrast Ratio, 300cd/m² Brightness, 2ms Response Time, 2x HDMI Input, 1x DVI-D Input, 1x VGA Input, 3 Years Warranty - £169.99
A good all round upgrade IMO, slightly larger and Iiyama are renound for making good monitors
3) 27" Fujitsu SL27T-1 Widescreen LED Monitor
1920x1080 Resolution, 5000000:1 Contrast Ratio, 250cd/m² Brightness, 5ms Response Time, 2x HDMI, 1x VGA Input, 2 Years Warranty - £239.99
Big size upgrade and similar performance specs to my current monitor
Which would you choose with a max budget of around £200 +/- £25, would you pick one of the above or something different all together?
