Spec check
Sharlaw
Hey Guys, was just wondering if you could look over my proposed new spec for a machine. I would welcome any comments or criticisms.
Thanks in advance
Spec:
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz (Nehalem) (Socket LGA1366)
Asus ATI Radeon HD 4890 1GB GDDR5 PCI-Express Graphics Card
Asus P6T SE Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
Coolermaster Storm 'Scout' Gaming Case - (No PSU)
OCZ Gold 6GB (3x2GB) DDR3 PC3-12800C8 (1600MHz) Tri-Channel
Samsung SpinPoint F1 1TB SATA-II 32MB Cache - OEM
OCZ ModXStream Pro 600w Silent SLI Ready ATX2 Modular Power Supply
Noctua NH-U12P SE1366 CPU Cooler (Socket LGA1366)
No, it's in the right place.
Tbh I don't think anyones posted down to the fact you've picked out a fine rig!
If it were me I'd go for a classier case, but that's a personal thing.
Thanks Ham,
My problem with the case is that, although I want enough space inside for components and also good airflow. I can't really fit a big case due to not having loads of room at home.
Are there any other cases that you can recommend?
I think your fine with that case, its a good case and ive read alot of reviews on it :p
Your spec is perfect, i myself always like a little extra juice in my pse, i would go for a 850 min :p
yeah im with lynx, if your thinking about adding another grfx card later on your system will be ready for it with a 850w psu, if the 600w psu is down to not having enough funds you could always go for a non modular because the case you have chosen has plenty of room for cable management
Great, I shall take a look at some beefier PSU's, having the headroom for the extra graphics card will certainly be useful.
