maniac
For the past couple of days I've been thinking about ways to connect my headphones and the speakers to my pc but it's more complicated than it sounds.
From the sound card I use a 3.5mm splitter to connect both the speakers and the headphones at once and use either one or the other (or both for that matter
). But the problem is that I don't wish to let my headphones on while using the speakers, the speakers can be turned off so thats not a problem when using the headphones. Attaching and detaching the headphones all the time is not really an option I'm considering, and using the passthrough of the speakers control thingy is too messy for my taste.
So my question is, is there any way to work around this? How do you guys and gals connect your speakers and headphones so I might get enlightened or something?
