[font=arial, verdana, tahoma, sans-serif]I am having an issue with my mute function and believe it may be an issue with the driver for my Gigabyte GeForce GTX 680.[/font]
[font=arial, verdana, tahoma, sans-serif]My rig is connected to my monitor by HDMI from my GTX 680. When i mute the sound in windows, the sound continues to play. I can still adjust the volume using the scroll wheel on my keyboard (Corsair K90) even though the sound is supposedly muted in windows.[/font]
[font=arial, verdana, tahoma, sans-serif]I have checked all of the sound options and configurations, there isnt anything else i can change to make sure the mute function stops all sounds.[/font]
[font=arial, verdana, tahoma, sans-serif]It is definitely the 'NVIDIA High Definition Audio' device providing the sound as when i disable the device in device manager the sound stops completely. I have also disabled all other sound devices to see if the the sound was being transmitted via any other means but the only connection to the monitor is the HDMI and I have no other speakers.[/font]
[font=arial, verdana, tahoma, sans-serif]Can someone help with this? [/font]
