aeozyalcin
Hey Guys,
I have a Sony Vaio VPCF136FM-B 16.4" Laptop.
Here are the specs:
Intel i7 740QM
6 GB 1033 MHz DDR3 RAM
640 GB 5400RPM HDD
NVIDIA GT425M @ Core 560 MHZ default @ Shader 1120 MHZ default
I am a heavy Flight Simulator X so I want to overclock my graphics card. I need to squeeze more out of my card to get a better FSX experience.
Its idle temperature is 45C.
I did a couple of tests with overclocking and tested the overclock with FurMark.
Here are the results.
Running the Benchmark Test with 1600x900, MSAA:8x at default clock speeds
http://img851.imageshack.us/i/capturegoz.jpg/
Running the Benchmark Test with 1440x900, MSAA:2x atdefault clock speed
http://img852.imageshack.us/i/capture00.jpg/
Running the Benchmark Test with 1440x900, MSAA:2x core @ 630, shader @ 1260 and memory @870
http://img402.imageshack.us/i/capture11n.jpg/
Running the Benchmark Test with 1600x900, MSAA:8x core @ 700, shader @ 1400 and memory @900
http://img856.imageshack.us/i/capture1t.jpg/
Running the Benchmark Test with 1440x900, MSAA:2x core @ 700, shader @ 1400 and memory @900
http://img508.imageshack.us/i/capture22uk.jpg/
Running the Benchmark Test with 1600x900, MSAA:8x core @ 730, shader @ 1460 and memory @930
http://img857.imageshack.us/i/capture2.jpg/
Running the Benchmark Test with 1440x900, MSAA:2x core @ 730, shader @ 1460 and memory @930
http://img571.imageshack.us/i/capture33c.jpg/
FurMark Stability test at 1440x900, MSAA:2x core @700, shader @ 1400 and memory @900
http://img864.imageshack.us/i/furmark000000.jpg/
In the Stability test the temp got up to 75C and it was almost stabilized at 75. If I had let the test go on for a little more time, it would stabilize at areound 76-77 C. My question is, would you recommend me to overclock it, or are the temps too high? What frequencies would you recommend me?
PS. I am thinking about buying a Cooler Master U2 laptop cooler in near future.
Thank you
Here are the specs:
Intel i7 740QM
640 GB 5400RPM HDD
Thank you
