way 2 go frag but i cant rep ya ne more
well @ least ma firefox translator extension works
<<<--------the following is and article from
http://www.pcpop.com/doc/0/86/86886.shtml that has been translted into english---->>>>>
AMD next generation connection! Socket M2 and S1 forestall to look
Issues the date: On May 06, 2005 author: LEE edition: LEE
Uses the needle foot in view of the AMD next generation table model processor the guess all kinds of, today but we finally had found about the AMD next generation processor Socket M2 real picture, the former all sorts of guesses already became the reality!
The AMD next generation table model processor uses Socket M2, used with present Socket 939 same PGA seal, the needle foot several returned to 940 needles, but was allowed to see Socket M2 obviously incompatible Opteron as well as Athlon from the foot place Land position 64. On the other hand, the AMD next generation migration processor will be able to use Socket S1, the needle foot several from 754 reduces to 638, will achieve miniaturized the goal. Simultaneously AMD listened to many notebook computers manufacturers to reduce the chip area the request, simultaneously reduced it to consume the electricity, from this was worthy of looking at this company even more diligently to develop the motion processor market the determination.
Opteron special-purpose Socket 940
The left chart for moves version Socket S1, the right chart for table model machine Socket M2
The AMD table model machine processor connection no longer uses the digital sign note
But this time changed the experts in view of the AMD needle foot also to propose once more some anxieties, double core Opteron published in namely, the Athlon 64 double cores looked like also can partly start after this year. If does not have the change, again does not pass through for half year to have to start the new foot place shift, the DIY user can accept is a not small question. On the other hand, also some many motherboards factory pointed out, is unable in Intel CPU to break through the high performance bottleneck under present situation, the success enters 90nm system regulation Athlon 64, not only is the double core, even if is the single core system overhead construction also extremely has the charm. Specially so long as can succeed supports the SSE3 instruction collection, but the video frequency code and the multimedia potency then greatly promote, then the C/P surface superiority is more formidable.
