Smallest Transparent ATX case
Status
Not open for further replies.
Mr.EU
Please Help to find all this in one case:
a)205mm(w)X585mm(d)X435mm(h) :huh:
b)ATX case :o
c)one side o/r full-case partially o/r full transparent :angry:
d)front usb+audio+mic port
e)with front 3.5 drive where i can install floppy drive (yes i need to use it some time for my school projects!!!)
last but not the least i am from Kolkata<India; but u may also suggest outside India
Please help me; Thank you very much ... :worship:
transparent???? WHAT?
You are kidding right......
just like any acrylic case... or one side fully or partially covered with acrylic sheet or any other type of panel; such that i can view the inside of the case from outside....
that is why i called it Transparent :)
So what you're actually looking for is an ATX case with a side window. Your first post sounded like you wanted the entire case to be transparent! :)
If entire case is available then it is the BEEEESSSSTTT :but i dont think it's available
so a side with window will be good
thanks for rply... :worship:
If the whole case was transparent we woulnt know about it because they are TERRIBLE.
Ugh makes me feel dirty just thinking about it!
apevia X-DREAMER 3 available in India through ebay...
RAIDMAX Fusion
Raidmax typhoon
rosewill future with front panel
and many LOGISYS ATX mdi tower case...
which is the best??
Aren't there any decent cases available in india like Corsair, Antec, Cooler Master, Bitfenix..? They all do cases with a window
As above the cases you posted look really cheap
I think you should buy what you like tbh. If we have not reviewed it dont buy it.
Pretty simple. Look on the front page of the site if you need anything else.
Closing thread I can see where this is heading.
Status
