shadow.nl13
hey guys,
looking to do something a little different. i want to build a small PC with enough power to do some gaming on it (the quieter the system the better).
I have ran into a bit of a 'bump in the road' and not sure how to get over it.
Currently the build i am thinking of goes like this:
-FM2 mini itx board (maybe ASRock FM2A75M-ITX)
-AMD A10-6800K
-Some form of 2100 RAM
-Sapphire HD 7750 Low Profile
-And of course a small case (maybe Streacom ST-F7CB)
The problem is the PSU, so to speak.
the three options i have avablie to me are:
1) use the Streacom Nano (which is my least favorite option)
2) Find a FM2 board that has a built power adapter (The laptop kind)... Do they even exist?
3) Try and find a case with built in power that is around the same size and which will still fit my GPU in.
If anyone is thinking option 3, can you please give some explains of some good looking, small itx cases that have built in power and will fit a low profile card in.
thanks guys
-AMD A10-6800K
thanks guys
