Signature max sizes, etc
Ralm
Hi there,
Can anyone provide me details or tricks to be able to use the full width of the signature box with content??
The dam BBCode creates a new line for everything I place there other then text, is just annoying.
I know that you can put a 800pixel wide picture in there, but the resizer thing will not accept anything bigger then 400pixels wide I think, and the option for use an picture for signature only allows a tiny 468x60pixels, when you can add pictures normaly like 400x 250 at least. Just weird.
Anyway,
does anyone have any ideia on how to get an image using the full signature space??
Thanks.
The ideia is not use more then 150px high.
I started using 300, but then it looked massive. I think 150px is good, but taking all the width of the template makes it easier and look better, since you cant use tables, you do a big 800x150 image with everything on it.
Edit:
Tom can you change the default resizer width size to 800pixels??
I tested the template and it doesnt go smaller then 930 or whatever it is, so its safe.
Please? :D
