Shutdown Timer I Made
Haha, maybe usernames probably am I right?
What you think of the new version then, still need to iron out some bugs, and it's speed but that's about it.
Shutdown Timer v2.5 Beta 2 has been released!
The main changes are a few GUI changes plus integration of Core Temp to allow you to take certain actions using the CPU temps.
There is now a 32 Bit and 64 Bit version, so users cannot upgrade their current version on the system if their OS is 64 bit.
Download and information here
Lil bug in Winxp
I have been working hard on the final version of Shutdown Timer, a lot of testing and implementing new ideas, also a lot of code improvements and fixing memory issues.
The final version of v2.5 should be released sometime this week!
Shutdown Timer v2.5 Final has been released!
A lot of code changes have been made and I hope everyone likes this version!
Here's a list of changes from 2.5 Beta 3:
- Fixed issue with program not remembering options correctly.
- Decreased Application Startup Time
- Fixed some areas of the program where it was causing memory leaks
- Added Help Documentation
- Fixed issue with Core Temp not being read when required checkbox is enabled
- Fixed issue with CPU Temperature module only reading first Core Temperature, now it finds the highest temperature
- Fixed issue with Date Module not working unless it's a UK Region Setting
- Added Hotkeys for Preferences and Help
- Changed Logo in About Window
- Added Opacity Preference setting
- Altered some interface controls to better suit the program
- Added Compact "Gadget" Style version when activating Shutdown Timer
- Added Monitor - Standby Shutdown Option which will put your monitor into standby mode when the time has reached.
Download and Information can be found here
What do you guys think of what v2.7/3.0 looks like?
If your wondering why the Networking Options is highlighted and the Time & Date Options is being shown it's because I'm just giving a little demo on what happens if you move the mouse over the icons.
Feedback and your views on it will be great.
Shutdown Timer 3.0.8 has been released.
Changes are:
- Information button on the new update notification now works and will tell you more about the update you will download
- The design of the different categories have changed, they are now labelled "ENABLE" instead of the older "Activate" also they have been tabbed
- Fixed the problem when going on the feedback area that the action box was interrupting it
- CPU Usage Value crashed when removing the value, this problem has been fixed.
- Improved Start Up Time
Download & Information
hey fella are you on EOCF aswell
Hi Yes I am on EOCF
