Should i upgrade my intel core i3
STV
Hey!
Should i upgrade my intel core i3 with phenom x4 or fx-4000 series. Or sould i replace at all. PS: in have tight budget :/
Why would you change an Intel chip for an AMD chip on a low budget, because then you'd have to buy a new motherboard too? o.-
If you want to get an upgrade, then get an upgrade. If you tell us your current specs and how much you want to spend, along with what you intend on doing with your PC, we can help.
I'd think if you have an i3 already, it would make more sense to buy an i5 and put it in the already-compatible mobo..?
Without the spec list we can't really help ya mate
