L Luigi New member Nov 18, 2007 #1 i was having a crack at getting a decent fsb with my quad on my striker (go to 450mhz!!) however the voltages in probe were all over the place. so, being worried, i changed the, back, and now they wont change. should i be worried?
M Mullet New member Nov 18, 2007 #2 Does the bios look OK? If it all looks fine try checking with a different voltage monitoring tool? Also, are temps comparable with those seen before the apparent voltage reading issue?
L Luigi New member Nov 18, 2007 #4 i dont have a voltmeter though lol, well i mean the temps are all on par with what they should be, what other prog can i use to monitor volts? it all still works, would it not have died by now?
