I am not sure if this is the proper section to post, but I assume it will get bummed if so.
I have been gaming on computers since I was like 10 or so (currently 26), however I only built one really nice rig one time back in 2008. I am, as you can guess, a huge gamer. Looking to stream, record, vlog, game etc on a high level (assumed the purpose of the build was important). I am currently looking to build a new rig and I want to make sure that everything will work together (along with some other questions).
For example, can I still use my Antec 850 Watt model number: TPQ-850 will be able to power my new rig? I know that it says it is designed for up to 4 cores, and I have the i7-6900k on the way.
Another one of my other worries, is getting new memory and it not being compatible with my MoBo (I was hoping for some suggestions or direction with that- since I want to get faster speed memory)? I am on the fence with what motherboard to get hopefully you can help me out ☺. Sure, I can pay $600+ dollars for a motherboard, but I am not sure that I need all the features I am paying for. That being said, I am leaning towards MSI’s Gaming Pro Carbon, but can’t find memory that will be compatible with the board (I know there are the OC Speeds 3000+ but does that mean I can just stick some 3600 speed sticks in there and it will be fine)? I have heard that some people when they put too high speed of memory into boards, they won’t even turn on. I am trying to avoid the sending it back and finding the compatible memory through trial and error.
In addition, I want to make sure that I can maximize the usage of my PCI lanes, since I will be having SLI 1080s (EVGA Classified), 2x Samsung 850 Evos, and not sure if I am going to use or can use the thunderbolt business etc since I am fairly new to reading about it. Hopefully, one of the motherboard listed, or the Gaming Pro Carbon can hold all the need components.
An SSD question, is 2x Samsung 850 1TB Evo’s fine to have together? I ask, because of the U.2 and M.2. I am not sure if I need different SSDs or not.
Last other random question/thought, is will the case fit everything I have listed below, little worried since it is a mid tower (IN WIN 805 Black Aluminum Tempered Glass ATX Mid Tower).
Anywho, let me just list the parts I am looking to get (I have a tendency to rant lol sorry):
Tracking List for Parts May/June 2006 Build
Motherboard— (I am leaning towards getting the X99a Gaming Pro Carbon, but I am open to your suggestions)
ASUS ROG Rampage V Edition 10
Or
X99A Gaming Pro Carbon*
Or
ASUS Signature X99 Deluxe II
Or
X99A XPOWER GAMING TITANIUM
Or
ASUS ROG STRIX X99 Gaming Motherboard
Or
ASROCK X99 Taichi Motherboard
Or
Fatal1ty X99x Killer/3.1
GPU— (I am pretty set on the Classified, but once again open since I have not ordered yet)
2x Gigabyte GTX 1080 Xtreme Gaming
2x The MSI GeForce GTX 1080 GAMING X
2x EVGA GTX 1080 Classified *
CPU— (Coming in 4 days ☺)
Intel Core i7 6900k
Memory— (Haven’t ordered yet, since I am not sure if it will be compatible with the CPU and motherboard)
Corsair Vengeance LPX (8x8GB) DDR4 DRAM 3600MHz
SSD/HD—
2x Samsung 850 Evo 1TB (waiting to purchase)
1x Samsung 850 Evo 500GB (Currently have)
1x Blackwidow HD (Currently in system?)
Cooling System— (From current system, I think it's a really good cooler, unless you recommend another fan— I have always been worried about liquid cooling my system, open to suggestion)
Cool Master Hyper 212 Evo
Cooling Fans Case—
5x ML Pro by Corsair 120mm in white led
Monitors--
Main Monitor: (choices; side note, not sure if I will need the gsync for FPS games I will be mainly playing):
Acer Predator XB271HU bmiprz 27-inch WQHD (2560x1440) wide screen w/ gsync
Asus Rog Swift PG278Q 27-Inch 2560x1440 144hz w/ gsync
(don’t see why I would pay another $300 for the PG289Q)
Second Monitor— Asus from back in 2009 1920x1080 5ms (50-60hz 1.5A)
Model #: VH242; Version #: VH242H
Power Supply (kind of worried if it can handle the i7-6900k since it says it is only designed for up* to* 4cores):
Antec 850 watt from back in 2008
Model #: TPQ-850
Case: (plan on removing the HDD Case to make space for the 2 120mm fans)
IN WIN 805 Black/Black Aluminum Tempered Glasses ATX Mid Tower Computer Case
Thanks for y'alls time in helping me out!
Warm regards
Or
Or
Or
Or
Or
Or
Intel Core i7 6900k
SSD/HD—
Cooling Fans Case—
Monitors--
Model #: TPQ-850
Warm regards
