Henrik
I'm sorry for you m8..
I have also done some reading on "safe" volts for the SB. There are allot of forum threads out there where people are stating that 1.52V is safe for SB. Just because they read a Max Vcore in the Intel document. Now where on page 80 of the following document
http://www.intel.com/content/www/us/en/processors/core/2nd-gen-core-desktop-vol-1-datasheet.html) stats that it is SAFE. It only stats that 1.52v is the max voltage.. In other words i believe it is the max voltage you CAN run before damage will most likely accrue. That dose not mean electromigration is not present up to 1.52V... We all know that you will degrade a CPU faster with higher volts or/and higher temperature. Witch means electromigration is dependent on temperature and voltage. Then why dose not Intel specify a max SAFE voltage?... I think its because every CPU is different and they will not all degrade at the same speed at higher Vcore. Some degrade very fast other not as bad.
If you would have asked me I would think that 1.4V will not degrade your chip within 1,5 year period. You must have had very bad luck m8.
