Samurize Config FAQ
FalconFX
This Tutorial is about Serious Samurize 1.61.
Its a Hardware Monitor system linked to your desktop. Downloads and PlugIns you can get here : http://www.samurize.com/modules/mydownloads/
After a succesfull installation you have to Restart the whole System.
Now do not start the Client. Start the Configuration Editor.
Here are some Basics :
-Changing the Grid :
To change the Grid-Size is an important Step to get your Samurize customized perfectly.
In the Configuration Editor look at the bottom. There you will see 2 fields with two 10's in it. Change this to a lower number. For example take "2".
-Adding some Stuff :
To Add Samurize stuff on your desktop you have two ways.
Lets begin with the right klick way.
Just right Klick in the Grid with your Mouse right Mousebutton. Now you can see a few options that i will explain later.
The other way to do it is the Tap way.
In the right corner of the Config Editor you can see 3 Taps.Edit Meters, Edit Graphics, Project Options. To addsamurize PlugIns choose the Edit Meters Tap. Here you will have to click the Add Meter Drop down Menu. Now you should see a familiar Menu.
-Giving your Theme a Name
Click in the Tap Menu on Project Options.
Under Project Name fill in your Theme Name.
You can leave the rest like it is.
-Starting Samurize
Just start the Samurize Client and change the following options per right click on the "S" icon in your Taskbar.
PIN TO DESKTOP (Compact Mode)
Right click on the S Symbol in Taskbar
Locked Position
Position
User Designed Position
-Graphing with CPU Example
1.Right Click in your Grid
2.Add Perfmon
3.The Option automatically Highlighted should be named : Processortime or so on
4.Choose Processortime and _total
5.Now you see a Number in Percent
6.GO all the was on the left to first tap : General
7.Klick : Drawtype : Graph
8.Go to Display Tap
9.Customize the Graph Lenght and Color
->Starting to Create your Theme
-CPU Performance in Numbers
2.Add Perfmon
6.Go On the right side of the Editor to : Display (3rd Tap)
7.Change "Perfmon" to CPU Usage and leave the %v
8.Now change the Position to where you need it in the Grid.
-Displaying HD Size
1.RightKlick On Grid
2.Add Drive Space
3.Go all the was to the right to : Scource Tap
4.Choose your Drive
5.Select Your Method (Free Space, Used Space etc.)
6. Select your Measurement (GB)
7.Go to Tap "Display"
8. Change Free and "mb" to whatever you have set in Scource
-IP with ROUTER Tutorial
Download this File : http://www.samurize.com/modules/myd...p?cid=6&lid=460
and extract the File in your Script Folder.
1.Right Click On Grid
2.Add Plugin
3.Tap : Scource
4. Select Active Script -> SpectrumVIS.dll
5.Display : Replace "PlugIn" with "IP" leave the rest like it is
-Free Ram Display
4.Right Click Grid
5.Add Memory
6.Scource Tap : Check the right Settings (Physical,Megabytes, Free Mem)
I will try to Add Stuff over Time here.
-FalconFX
