Samsung galaxy s2 charging problems
cbiltsouris
hey everyone
Ive had my s2 for a couple of months now and alll of a sudden i cant charge it at all
I have the lightning rom and the phone has been rooted so its not on the normal one from samsung
I just dont understand why all of a sudden it wont charge?
hey man soz it does charge on my pc through the pc which gives me some sort of relief but it refuses to have anything to do with the actual phone charger
It might be a fuse in the charger itself that is busted since you can charge via the PC. Just buy another mains charger and you should be OK
yeh I think thats the problem, Ill probably buy the bigger battery for it that gives it 3200ah instead of the standard 2000
cheers mate
No problem
. It could also be the socket that is the problem. If you haven't checked the charger with a different socket do that as well just in case.
Also you can buy external chargers to charge the battery without the phone so you can have a fully charged backup.
HERE is one I used for my old phone, when the connection area was so bad I couldn't charge it with any mains charger.
