P purplemonkey New member Apr 21, 2008 #1 Which one these two is best? Can't decide... looking to do graphics work, along with gaming and movies
N Nick R New member Apr 21, 2008 #2 If your looking for a 22", the samsung 2232BW is the best of the bunch.
P purplemonkey New member Apr 21, 2008 #3 from what i can tell 22" gives best bang for buck the Dell 24" ultrasharp is about double the cost of the 22"!!!! Am I correct in thinking the 2232BW is the replacement for the popular 226BW
C cl0ck_ed New member May 7, 2008 #7 You'll notice very little difference between the samsung panels mentioned when they have been set up proparly. Go the the cheapest samsung you can find apart from the ones on ebuyer that are about £160, these panels are a lower quality.
P purplemonkey New member May 7, 2008 #8 URGENT Do i go for the T220 from Samsung or the 2232BW??? Ordering tonight or tomorrow!
I inonefly New member May 8, 2008 #9 have a look at digitalversus, you may chose one with less input lag if you play fps games
