safe temps?
unknownuser200
I was doing a update on a buiild for a friend, his setup
g1 guerrilla by gigabyte
990x
evga 260gtx
corsair 600t
h80
hx850
corsair force 3 120 (raid 0)
etc etc
problem i seem to encounter is the northbridge idles at 45*C-48*C i was wondering if that was trypical?
it feels very phsyically warm to the touch so the heatsink is making contact
i tryed putting a 40mm fan blowing directly actoss the heatsink fins which didnt really do anything (may not being moving enough air)
side panel makes no difference as theres no longer a heat build up on or off theres about a 2*C difference in temps.
cpu idles at 32*C
Every other motherboard temp is reading 34*C so its honestly just the northbridge that has me worried
airflow isnt an issue its very neat and tidy (ttl tidy)
cpu as at stock atm
well just ran prime 95 for 45 mins on this rig for him
cpu temps never exceeded 51*C with the cpus fans on medium
now im kinda confused which is the north bridge temp but im guessing its one the hotter ones
System temps under 100% load
system 38*C
System 1 50*C
System 2 50*C
System 41*C
thoughts? anyone know which one the NB is? and if all these temps are safe. I know the cpu is safe but im concerned about the otheres
hmm see my guess's were the
system was the little sensor by the ram...
system 1 was north bridhge
system 2 was mosfets
system 3 was south bridge
being northbridge and mosfets are on same heatpipe cooling solution the similar temps would make sense , but honestly thats just all a guess
The x58 chipset can handle up to something like 100C, obviously it wouldn’t be prudent to expose it to those temps for any length of time.
Mine is up to 60C at idle, and according to the manufacturer is perfectly acceptable.
Anyway, your temps are fine.
I don't know what the idle temps are; but currently folding with an open bench like set up with no incidental airflow beyond the tower CPU heatsink, my infrared thermometer is showing 80°C on the North Bridge heatsink. This is a Gigabyte LGA775 board.
