KING_OF_SAND
So for the last two days my 990fx sabertooth has been giving me issues. I keep getting the red led which indicates their is something wrong with my gpu. I don't get any beep code or anythin, just a red led and a black screen. I did the clear thing first, that being jumping the motherboard, no luck. So I thought it was the gpu, so I switched my 6990 with a 5770, same issue, then I tried a 9600gt with still the same issue. then I moved to the psu, maybe it was not giving enough power which makes no sense because a beep code would have told me that. So I went about any ways and swapped my ax850 with a xion850 and still the same thing. Is their something that I am boarding here? It does not seem my motherboard is broken? It seems something is frozen in the motherboard and it just won't turn over.
Ps I also tried different pci lanes.
Pps all the gpus work.
If someone has anything to bring to the table please let me know, my pc is quite latterly my life support. I an using a temporary netbook I picked up yesterday after this happened and us soooo slow.
I did this on my phone so forgive any errors. Thank you.
