bazskating
so I was asking for some advice on what to get for my brothers PC here's what I went for in the end!
NZXT H440 white and black case
Ryzen 5 1600x
MSI x370 gaming pro carbon
corsair LED vengeance ram 16GB
Corsair RM650x
Corsair h100i v2
Strix 1070
did have a few issues the main one being I didn't think to upgrade the bios setting before trying to install the GPU driver! this resulted in the PC shutting down as it seemed to think it was getting to hot! so I ended up removing and refitting the CPU cooler! anyway long story short I figured out in the end that the CPU was reading +20c and after the bios update it all worked as it should!
Brother is very pleased with his shiny new PC and playing games at full resolution compared to his old rig!
I was very happy with cable management in the end! as this is only my second build.
Ryzen 5 1600x
Corsair RM650x
Corsair h100i v2
Strix 1070
