Runtime Error 217, How can i fix this?
SillyOldSquid
hello all,
I booted up my rig today and I got a Runtime error 217 at 00159489 on my desktop, does anyone know what this is or how I can fix it?
Google says
"Runtime error 217 is like other Runtime Errors in that is not all that uncommon. This error is typically associated with PC users who have just installed Norton and/or upgraded their Internet Explorer version with the problem being the computer is not recognizing something with one or both programs."
Runtime Error 217 Symptoms
Runtime Error 217 can make it so you can’t access certain programs or files properly. Additionally, with this particular Runtime Error an overall slowdown of the PC’s speed is usually a frustrating side effect and when left alone it only intensifies.
Runtime Error 217 Causes
Runtime Error 217 can be caused by a couple of different things. It might be that a virus was installed along with the new program you installed. It could also be that your computer’s registry is too cluttered and therefore didn’t allow the program to be installed properly. If this is the case, the computer and the program will battle back and forth to provide information for one another.
Fixing Runtime Error 217
A quick anti-virus scan is never a bad idea when any Runtime Error occurs and Runtime Error 217 is no acceptation. However, if that doesn’t work you can try the following to elevate the problem:
Steps:
Click Start Button.
Click Control Panel.
Select Internet Options.
Select Programs, then Manage Add Ons.
Locate Norton Confidential Browser Helper in list being used by Internet Explorer.
Click Disable.
Click OK to confirm.
Restart your computer allowing changes to take hold.
If it were me, I'd get that piece of shit Norton uninstalled with all due haste.
Google says
Tut tut SuB, I thought swearing is prohibited on the forums? Heh, s'pose it can't be helped in some cases, this is understandable if the OP is using Norton :lol::lol:
Google says
Thanks for the help I have never had Norton on my system so I have a feeling it could have been a virus, I did a scan, found 4 potential threats and removed them so hopefully it wont pop up again.
It is prohibited. But this is Norton we're talking about here!!
No probs, hope you sort it out.
