I have a thermaltake water cooling system with a front bay with flow indicator, which keeps stopping and clogging up but water still flows perfectly. the noth block, cpu is cooled and it cooled by 3 radiators. 1 small and 1 big twin radiator. I had a few problems where the supplied p4 pump failed and would not pump. since i had it replaced by an alphacool p6 pum with built in resevoir it has been more reliable. The problem i have is that it runs alot hotter since i upgraded to a powerful pump. used to be bout 18 degrees to 25 degrees on idle and 30 degrees under very heavy load, No hotter than 35 degrees. Now it runs at 30 idle and 40 under load. My processor is an AMD toledo 4400 939 socket. Is there anythink i can do to make it run cooler. Im in a themaltake kandalf case with 4 case fans. Another thing is when the pump starts up it clucks and clicks a few times then goes quiet.
Thanks in advance
Richard Chowns
Thanks in advance
Richard Chowns
