RandomBadger
Hey guys, I've just installed custom loop and finished a 24hr leak test and all was good.
So I've powered on my system for the first time and it's running hotter than it did with the H100i, is it just settling or should I be worried.
Do you think I need to re-sit the CPU block and re apply thermal paste?
CPU is 4970k @ 4.4GHz and package temp is 30°c - 40°c idle.
And each core temp is jumping around 29°c plus.
Even when idle the CPU usage seems high.
Any help would be appreciated.
Can do a full spec list if needed.
