Game Over
Ok, I am sure asking this on this particular site is probably like asking if it matters which foot you put a sock on, but I have been using a 32bit system for ever and will soon be upgrading to 64bit for the first time.
I have several expensive programs that are all in 32bit formats such as Photoshop to name one.
I am assuming that these 32bit programs would run just fine on a 64bit system?
And a second question....
Assuming the above is correct, and using Photoshop CS5 as an example, lets say I have a 64bit PC, and run both a 32bit and 64bit Photoshop CS5. Or any other program for that matter. what difference if any would I notice between the two? Better graphics, Faster Operation?
Never had to give this too much thought. Another reason I ask the second question is I am about to make a purchase on a autocad program and wondering if I would be better to hold off and get the 64bit version for the future rig or go ahead and pick up the 32bit now. if the 32 will not run on a 64 OS, or the 64bit Autocad runs better than the 32 then I would want to wait, but if I am not going to see any difference... That goes for some other programs as well.
